I have a reference dimension from a flange to a sphere but when I generate the ISO for this line, all items are placed on the same position.
This doesn't happen when using the default ISO template so I guess the issue is with our custom template but I am not sure what could have changed in our template to cause this.
Dear @arron.craig,
You can be sure we don't know what you changed in your custom iso style either. 😁
But you can compare the two IsoConfig,xml on content maybe this will help you.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
When we want to see any differences between the isoconfig.xml files of different styles we put them in https://www.diffchecker.com/diff it's just a tool that'll show the differences between files.
Thank you. I compared the two iso styles and the only differences where expected.
I did notice that the reference dimension works fine when placed on pipe or other fittings in the line. I then narrowed it down to that flange in particular. After deleting and replacing the flange, the reference dimension works now. 😐
