AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Inserting a reference dimension breaks ISO drawings.
3 REPLIES 3
arron.craig
260 Views, 3 Replies
I have a reference dimension from a flange to a sphere but when I generate the ISO for this line, all items are placed on the same position.
This doesn't happen when using the default ISO template so I guess the issue is with our custom template but I am not sure what could have changed in our template to cause this.
3 REPLIES 3
h_eger
in reply to: arron.craig
Dear @arron.craig,
You can be sure we don't know what you changed in your custom iso style either. 😁
But you can compare the two IsoConfig,xml on content maybe this will help you.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
When we want to see any differences between the isoconfig.xml files of different styles we put them in https://www.diffchecker.com/diff it's just a tool that'll show the differences between files.
George
If my post offers a solution, please click "Accept as Solution"
Thank you. I compared the two iso styles and the only differences where expected.
I did notice that the reference dimension works fine when placed on pipe or other fittings in the line. I then narrowed it down to that flange in particular. After deleting and replacing the flange, the reference dimension works now. 😐
