AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
If there are two EngagementLength values
2 REPLIES 2
s.sakumaVWAS3
97 Views, 2 Replies
Hello. This text was created using the translation function.
If there are two EngagementLength values, Is it possible to show both values ​​in the isometric drawing?
I edited the XML file as shown below, but the value of S2 PORT was not displayed.
<ComponentScheme Name="エルボ(抜代)" AnnotationStyle="Standard" Format="{0}\P{1}" Enabled="true" GroupingOrder="0" Grouping="false" Alignment="FlatHorizontal" LeaderStyle="Leader-AsNeeded-NewArrowedStyle" Filter="エルボ-1" Fields="EngagementLength EngagementLength" />
2 REPLIES 2
h_eger
in reply to: s.sakumaVWAS3
@s.sakumaVWAS3 ,
this is because the value for EngagementLenght is only saved for S1 under EngineeringItems, the value for S2 is saved in the Port table.
Technically, you would have to create a view in Piping.dcf by querying both values and entering them in a separate field under EngineeringItems.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Thanks for the reply, I'll do some research on my own.
Technology Administrators
