Hello. This text was created using the translation function.
If there are two EngagementLength values, Is it possible to show both values in the isometric drawing?
I edited the XML file as shown below, but the value of S2 PORT was not displayed.
<ComponentScheme Name="エルボ(抜代)" AnnotationStyle="Standard" Format="{0}\P{1}" Enabled="true" GroupingOrder="0" Grouping="false" Alignment="FlatHorizontal" LeaderStyle="Leader-AsNeeded-NewArrowedStyle" Filter="エルボ-1" Fields="EngagementLength EngagementLength" />
Solved by h_eger. Go to Solution.
this is because the value for EngagementLenght is only saved for S1 under EngineeringItems, the value for S2 is saved in the Port table.
Technically, you would have to create a view in Piping.dcf by querying both values and entering them in a separate field under EngineeringItems.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
