How to include Puddle/Thrust flanges?
Brendan_RaymondBMUQZ
Message 1 of 11
Does anyone know how I can add a thrust/puddle flange on a simple pipe spool?
Looks something like this.
Incase it's relevant, the material is ductile iron cement lined, and I use a combination of flanged, spigot and socket connections. Flanges and fittings are to Australian standards.
Thanks in advance.
Replies (10)
Message 2 of 11
Tomislav.Golubovic
Is it a one piece item? Just add it as a spacer/coupling in the spec with the dimensions from the data sheet.
Message 3 of 11
Thanks for the reply. Correct, it is a one piece item.
Though I'm not sure i'd want to use a coupler or a spacer? Wouldn't that split the pipe in 2?
Worst case scenario, I could have the puddle flange a separate item, though I don't want it to split the pipe in half.
Thanks.
Message 4 of 11
Tomislav.Golubovic
Ah doh, I just looked at it and thought coupling.
You could make a block for it, then put the insertion point in the middle. Only thing you'd need to do manually would be to delete the weld on the Iso. I can't see any other way to do it automatically.
Message 5 of 11
Thanks.
Though is the parent pipe still a single piece, or does the coupling split it (at the red point)?
If all else fails, I'll just use a 3D object to illustrate the flange... Unfortunately that defeats the purpose of using intelligent Plant3D.
Message 6 of 11
Tomislav.Golubovic
Yeah the parent pipe is still split. I think I've seen others try using a "Support" because then it doesn't put in the weld, but its going to come out on reports as a support.
Message 7 of 11
h_eger
@Brendan_RaymondBMUQZ ,
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 8 of 11
Tomislav.Golubovic
@h_egerits kind of a "sleeved" pipe so it sits over the pipe, not actually attach to it.
Message 9 of 11
In this case, its ductile iron cast into the pipe so its a single homogeneous part... However you can buy bolted sleeved ones, I would imagine they would need a different solution.
Message 10 of 11
Michiel.Valcke
@Brendan_RaymondBMUQZ  I haven't encountered such a part before, what are they used for?
Message 11 of 11
They are for underground pipework. Usually the puddle flange is concrete encased, usually in thrust blocks or in the side of a bund or tank wall or valve pit.
