Dear All,
In an existing Plant 3d Model the model is showing stub Flange and loose flange on top of another one. Is there is any way to fix it .
Thanks & Regards,
Rafi
The backing ring should be on the other side of the stub end. Which item did you place first?
have you already attended training on how to work with Spec Editor?
Have you also entered the flange offset in your stub end?
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
who created the Pipe Spec and the associated catalogs?
Without a catalog, the pipe spec cannot be adapted.
Hartmut Eger
Senior Engineer
XING | LinkedIn
without a catalog there is NO way to solve the problem!
Hartmut Eger
Senior Engineer
XING | LinkedIn
If you can use Spec editor you can double click on the flange(collar) and go to the end of the parameters and look for "OF" if there is one and set it to -#. The thickness of the stub end. See if that works.
Load the spec file to post.
Just pick another catalog like the ASME Pipe and Fittings and continue in the spec. Double click the collar/stub end in the spec editor (not in the catalog editor) and edit the Flange Offset from there if necessary. If you don't know the value, scroll to the end of the properties and lookup the geometric properties and copy those:
