AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
API: How to read (and change) drawing properties defined at the project
3 REPLIES 3
sbarlage
267 Views, 3 Replies
sbarlage
I try to read out all defined drawing properties of the active drawing as shown in screenshot.
All this should be done inside of my addin. The properties should be read at DocumentSave event (Event is already implemented and working, I get "Autodesk.AutoCAD.ApplicationServices.Document" as parameter from Autocad at the OnSave event function.
Can someone points me to the how to read the informations shown at General and ErpData?
Regards
Stefan
Regards
Stefan
3 REPLIES 3
sbarlage
in reply to: sbarlage
sbarlage
I forget to say, I'm using C# with Plant 3D 2024 and 2025.
sbarlage
sbarlage
I could solve it myself:
internal enum DrawingType
	Unknown=0,
	PID=1,
	P3D=2,
	Ortho=3,
	Iso=4
Autodesk.AutoCAD.ApplicationServices.Document activeDocument = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
Autodesk.AutoCAD.Interop.AcadDocument activeAcadDocument = Autodesk.AutoCAD.ApplicationServices.DocumentExtension.GetAcadDocument(ActiveDocument) as Autodesk.AutoCAD.Interop.AcadDocument;
Autodesk.AutoCAD.DatabaseServices.Database activeDatabase = ActiveDocument.Database;
Autodesk.ProcessPower.ProjectManager.PlantProject plantProject = Autodesk.ProcessPower.PlantInstance.PlantApplication.CurrentProject;
Autodesk.ProcessPower.ProjectManager.ProjectUnitsType projectUnits = pipingProjectPart.ProjectUnitsType;
Autodesk.ProcessPower.ProjectManager.Project pnidProjectPart = plantProject.ProjectParts["PnID"];
Autodesk.ProcessPower.ProjectManager.Project pipingProjectPart = plantProject.ProjectParts["Piping"];
Autodesk.ProcessPower.ProjectManager.Project orthoProjectPart = plantProject.ProjectParts["Ortho"];
Autodesk.ProcessPower.ProjectManager.Project isometricProjectPart = plantProject.ProjectParts["Iso"];
Autodesk.ProcessPower.DataLinks.DataLinksManager pnidDataLinksManager = pnidProjectPart.DataLinksManager;
Autodesk.ProcessPower.DataLinks.DataLinksManager pipingDataLinksManager = pipingProjectPart.DataLinksManager;
Autodesk.ProcessPower.DataLinks.DataLinksManager orthoDataLinksManager = orthoProjectPart.DataLinksManager;
Autodesk.ProcessPower.DataLinks.DataLinksManager isometricDataLinksManager = isometricProjectPart.DataLinksManager;
if (pnidDataLinksManager.GetDrawingId(db) != -1)
	drawingType = DrawingType.PID;
else if (pipingDataLinksManager.GetDrawingId(db) != -1)
	drawingType = DrawingType.P3D;
else if (orthoDataLinksManager.GetDrawingId(db) != -1)
	drawingType = DrawingType.Ortho;
else if (isometricDataLinksManager.GetDrawingId(db) != -1)
	drawingType = DrawingType.Iso;
else
switch (drawingType)
	case DrawingType.PID:
			// Get the piping drawing category names
			List<string> catNames = pnidProjectPart.GetCategoryNames(CategoryType.eDrawing);
			foreach (string catName in catNames)
				List<KeyValuePair<string, string>> props = pnidProjectPart.GetDrawingProperties(fileName, catName);
				foreach (KeyValuePair<string, string> prop in props)
					System.Diagnostics.Debug.Print($"{catName}, {prop.Key}, {prop.Value}");
		break;
	case DrawingType.P3D:
			List<string> catNames = pipingProjectPart.GetCategoryNames(CategoryType.eDrawing);
				List<KeyValuePair<string, string>> props = pipingProjectPart.GetDrawingProperties(fileName, catName);
		break;
	case DrawingType.Ortho:
			List<string> catNames = orthoProjectPart.GetCategoryNames(CategoryType.eDrawing);
				List<KeyValuePair<string, string>> props = orthoProjectPart.GetDrawingProperties(fileName, catName);
		break;
	case DrawingType.Iso:
			List<string> catNames = isometricProjectPart.GetCategoryNames(CategoryType.eDrawing);
				List<KeyValuePair<string, string>> props = isometricProjectPart.GetDrawingProperties(fileName, catName);
		break;
	default:
		break;
	Unknown=0,
	PID=1,
	P3D=2,
	Ortho=3,
	Iso=4
else
		break;
		break;
		break;
		break;
	default:
		break;
Michiel.Valcke
Michiel.Valcke
You're welcome to mark your own post as a solution ^^
