AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How to fix Error in Loose flange and Stub End.
14 REPLIES 14
Message 1 of 15
rafimh2022
468 Views, 14 Replies
Dear All,
In an existing Plant 3d Model the model is showing stub Flange and loose flange on top of another one. Is there is any way to fix it .
Thanks & Regards,
Rafi
14 REPLIES 14
Message 2 of 15
km4504
in reply to: rafimh2022
The backing ring should be on the other side of the stub end. Which item did you place first?
If my reply was helpful, please give a Kudos or click the Accept as Solution button below (or both).
Message 3 of 15
rafimh2022
in reply to: km4504
Hi Sir km4504,
Yes you are correct it was my mistake. I will re load the image.
Thanks for information.
Rafi.
Message 4 of 15
h_eger
@rafimh2022 ,
have you already attended training on how to work with Spec Editor?
Have you also entered the flange offset in your stub end?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 5 of 15
rafimh2022
in reply to: h_eger
Hi Sir h_eger,
Am not able to find the catalogue for that particular spec. Seeing message like below.
Any other solution sir.
Rafi
Message 6 of 15
h_eger
@rafimh2022 ,
who created the Pipe Spec and the associated catalogs?
Without a catalog, the pipe spec cannot be adapted.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 7 of 15
rafimh2022
in reply to: h_eger
Hi Sir h_eger,
The person who created the Catalogue is no more available
and the spec and 3d model is still active and catalogue is not available
so what will be the solution to fix it.
Rafi.
Message 8 of 15
h_eger
@rafimh2022 ,
without a catalog there is NO way to solve the problem!
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 9 of 15
km4504
in reply to: h_eger
@rafimh2022
If you can use Spec editor you can double click on the flange(collar) and go to the end of the parameters and look for "OF" if there is one and set it to -#. The thickness of the stub end. See if that works.
Message 10 of 15
rafimh2022
in reply to: km4504
Hi km4504,
I try to change but not updating OF. I can edit it to -# but after saving it is going back to-1.0
Thanks & Regards,
Rafi
Message 11 of 15
rafimh2022
in reply to: h_eger
Hi h_eger,
Then how the Spec is working with 3D Model?
Rafi
Message 12 of 15
km4504
Put a value in for the thickness of the flange. example -1, -1.25 etc...
Message 13 of 15
rafimh2022
in reply to: km4504
Hi Sir  km4504,
Catalogue is not showing. Whenever am searching for Catalogue, Spec editor is asking me to browse the location by saying that PE - HDPE Material is not available in Autodesk library.
Any way to edit the dimensions without Catalogue.
Rafi
Message 14 of 15
km4504
Load the spec file to post.
Message 15 of 15
Michiel.Valcke
Just pick another catalog like the ASME Pipe and Fittings and continue in the spec. Double click the collar/stub end in the spec editor (not in the catalog editor) and edit the Flange Offset from there if necessary. If you don't know the value, scroll to the end of the properties and lookup the geometric properties and copy those:
Technology Administrators
AutoCAD Beta
