HOW TO CREATE A REPORT CONTAINING TOTAL QUANTITIES?
omar.amohamed
Message 1 of 9
omar.amohamed
HOW TO CREATE A REPORT CONTAINING THE TOTAL QUANTITIES OF AN COMPONENT?
EXAMPLE:
I HAVE A MANUAL GATE VALVE SIZE 80 WITH A DIFFERENT TASG NUMBER
GV-01 / GV-02 / GV-03
I WANT TO CREATE A REPORT THAT CALCULATES THE TOTAL NUMBER OF GATE VALVES THAT HAS THE SAME SIZE
SO OUTPUT SHOULD BE >> GATE VALVE - SIZE 80 - QTY: 3
COULD BE ACHIEVED BY PLANT 3D ITSELF? AND IF NOT, PLANT REPORT CREATOR HAS THE ABILITY TO ACHIEVE THAT?
Replies (8)
Message 2 of 9
George.Endrulat
It depends on how formal and frequent you need the data, if it's informal and seldom you can use datamanager and export it to excel and do whatever you want, including totals.  If it's formal, a deliverable, and often generated you'll want to do it in report creator.  Report creator is somewhat complicated, I would recommend getting trained in it to fully utilize it.
George
If my post offers a solution, please click "Accept as Solution"
Message 3 of 9
omar.amohamed
YES, I WANT TO EXPORT TOTAL DIRECT FROM PLANT 3D LIKE IN REVIT.
Message 4 of 9
rajendra.prajapat
@omar.amohamed You can get it by data manage. use pivot table in exported excel to get the data in your format.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Message 5 of 9
Gokhan_Kaya
Hi
which one report  PİD  or 3d ?
Forumlarımızda çözülen sorularınızı "ÇÖZÜM OLARAK KABUL ET" ("Accept as Solution") seçimiyle işaretlemeyi lütfen unutmayın.
Beğendiğiniz mesajları lütfen "Övgü Puanı" ("Kudo") ile ödüllendirin.
Gökhan Kaya
Tehcnical Manager
Autodesk Inventor Certified Professional 2015
LinkedIn
MSI WS 60 i7 Quadro M2000M
Message 6 of 9
omar.amohamed
PID
Message 7 of 9
Gokhan_Kaya
Hi
I create new report file Valve list with qty
I am not test this report
Before using this file, be sure to check that it works correctly
compare data from report with datamanager
NOTE: There may be omissions and inaccuracies in the report. Please check and use
Gökhan Kaya
Tehcnical Manager
LinkedIn
Message 8 of 9
omar.amohamed
Thanks a lot, it worked.
Could you recommend me an advanced tutorial for P3D report creator?
Message 9 of 9
Gokhan_Kaya
Hi I have not any documents sorry
Gökhan Kaya
Tehcnical Manager
LinkedIn
