Ortho view cube
Ortho view cube
kevin.edwards6L7CR
Ortho view cube
kevin.edwards6L7CR
 For my work i route a lot of pipes through cellars.  When creating orthos it is hard to use the view cube and see exactly what is within.  Is it posssible to see just what is inside the cube and everything else be hidden?
h_eger
Dear @kevin.edwards6L7CR ,
not directly, but you can get a better overview by showing and hiding your 3D models in the Ortho creation.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
George.Endrulat
Sure, if you prep your model before ortho generation, you can do any kind of xclip (xref clipping) you want in a dwg then when you bring that clipped dwg into ortho generation it'll work as expected, still clipped.
George
If my post offers a solution, please click "Accept as Solution"
