Need help with setting up backing ring/LAPed joint/...
Im trying to have a pipe with stub ends form a connection.
So far i tried with backing ring having different end types, tried to combine it with pipes with different end types and had no luck.
Tried also with LAP end type flange and was again unsuccessful.
As i understand Plant 3D i create simple joint LAP-LAP, check fasteners (gasket+backing ring) and that should work. Pipe having FL end type and backing ring FL/LAP ends. Except my best result so far was connection with gasket only, without flanges/backing ring.
In attached sketch is an example of what im trying to achieve.
Can anyone help me with that?
