How to add grips using python scripting
tinuthomasGE9RJ
Message 1 of 8
tinuthomasGE9RJ
Hai Team,
    I'm a beginner in Plant 3d parametric component creation using python, I have doubt regarding adding the grips in custom components which I created using python scripting. can anyone help me in this topic..
Replies (7)
Message 2 of 8
h_eger
Dear @tinuthomasGE9RJ ,
you don't need to add grips, they are hardcoded and assigned to the respective components.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 8
tinuthomasGE9RJ
Actually I need to create supports with custom scripts, also need a flexibility of stretching it! will it possible with scripting?
Message 4 of 8
jabowabo
You can add stretch grips with the setLinearDimension function.
Message 5 of 8
tinuthomasGE9RJ
Thank you sir......can you share some examples of creating simple components with Rotation, moving, stretching, substitution grips etc. It will be very helpful for me to learn...
Message 6 of 8
jabowabo
Message 7 of 8
tinuthomasGE9RJ
I already tried above code, can you provide any other advance level codes...
Message 8 of 8
pavithra_bSSHFY
Sir ,
It shows access denied for refer how to assign grip for custom component using python scripting.
I am new to custom script, I am trying to load component with grip points ,please help me to assign how to add grip points for stretching, moving, rotation to custom components.
I request you to give some sample script regarding how to assign grips.
