Custom Saddle Tapping Valve Component
david.williamsUVTLL
david.williamsUVTLL
I'm looking to create a custom component that is a saddle tapping valve such as in this link:
https://ntgplastik.com/en/products/product/ef-tapping-valve
Other similar saddles/tapping components, i've created as block based 'olets' and this seems to work successfully. However, for this to be a valve, it seems to force it to be an inline component.
Is there a way I can make this component to be both a valve and a branching (tapping) component?
h_eger
@david.williamsUVTLL ,
Short answer: No.
There is currently no such variant in Plant 3D content.
I also don't know of any way to integrate these components into Plant 3D so that they also behave as valves.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
david.williamsUVTLL
Thanks for your reply.
Unfortunately this is what I was expecting.
I've created a suggestion requesting for this be added:
https://forums.autodesk.com/t5/autocad-plant-3d-p-id-ideas/saddle-tapping-valve/idi-p/13842547
Michiel.Valcke
A workaround would be to view it as two components, one is an olet, the other is a valve sitting directly on top of the olet. You can give the olet a different isotype to exclude it from the isometric BoM. You can even give it custom endcodes so that the only component fitting on the olet would be your valve.
david.williamsUVTLL
Yeah that would be a functional workaround. Thanks.
Could even create a compound joint that uses the olet as the connector.
