3D Rotate with specific base point command using python script
shreya_valte
shreya_valte
Dear Forum Experts,
I am currently working on a Python script for AutoCAD Plant 3D and need assistance with implementing a 3D rotation of an object around a specific base point.
In current case I am able to use only rotate command, but this command is rotating object around its CG point only. Expecting output as shown in image above, Kindly Guide.
h_eger
@shreya_valte ,
enclosed the documentation for the Python script under AutoCAD Plant 3D and its possible functions
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
