AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Flange adapter connection settings
4 REPLIES 4
Robby_J_B
305 Views, 4 Replies
G'day
I need help with connection settings for a flange adapter. Obviously one port will be flanged, the other must connect to plain end pipe. If possible the SKEY and correct iso symbol as well.
4 REPLIES 4
h_eger
in reply to: Robby_J_B
Dear @Robby_J_B ,
the end code "FL" is on the flange connection side
On the pipe side it gets interesting, I would set the end code to "BELL".
For the SKEY e.g. "FLBELL" it is a flange symbol with BELL connection, you have to configure it in the FLWN instructions.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Robby_J_B
in reply to: h_eger
Thanks @h_eger
I have got it to work using FL at port 1 and P (Press End Type)at port 2. I used COP for the SKEY. CO for coupling.
Here are my results. The only problem is that it looks like there is a weld on the iso.
I was going to try SL (Slip End Type) next.
Michiel.Valcke
The press joint normally adds a universal fastener. That is what you see in the iso. A Slip Joint does the same.
Robby_J_B
in reply to: Michiel.Valcke
Thanks @Michiel.Valcke,then I think I am good to go.
