G'day
I need help with connection settings for a flange adapter. Obviously one port will be flanged, the other must connect to plain end pipe. If possible the SKEY and correct iso symbol as well.
Solved by Robby_J_B. Go to Solution.
Dear @Robby_J_B ,
the end code "FL" is on the flange connection side
On the pipe side it gets interesting, I would set the end code to "BELL".
For the SKEY e.g. "FLBELL" it is a flange symbol with BELL connection, you have to configure it in the FLWN instructions.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
The press joint normally adds a universal fastener. That is what you see in the iso. A Slip Joint does the same.
