Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Isometic - Fittings and pipe not connecting
sam.mondelaers
sam.mondelaers
When creating ISO's my fitings and pipes are not connecting correctly.
Does anyone know what causes this problem?
Michiel.Valcke
What version of Plant 3D are you using. If you open the file in another version (2022 instead of 2024 for example) and then generate the iso, do you still have the same problem?
Have you installed all your available updates?
DVaquand
Hello
As @h_eger  indicates, try to place split points on the vertical parts
See topic
https://forums.autodesk.com/t5/autocad-plant-3d-forum/iso-sketches-issues/td-p/12550638
== French ==
Comme l'indique @h_eger , essayez de placer des points de cissions sur les parties verticales
Voir topic
Cordialement
Dominique VAQUAND
www.dovaq.fr
Si mon message propose une solution, veuillez cliquer sur "Accepter comme solution"
If my post offers a solution, please click "Accept as Solution"
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
