P&ID Transcription from dwg to Auto Plant P&ID
michelle_pintoEHV27
michelle_pintoEHV27
We have a large amout of P&IDs to transcript from dwg to auto Plant P&ID, but it is taking a lot of hous of work. Is there any way to become this job easier?
We already tray to convert by the ystem, but Just the equipments were converted.
Is there anyway to convert lines and instruments.
We also have to change the size of the sheet, and add all the conectors, so to do it in a easy way would heal a lot.
Thank you in advance.
Accepted solutions (3)
h_eger
Dear @michelle_pintoEHV27 ,
Do you mean AutoCAD Plant 3D P&ID?
Short answer: You will not be able to avoid redrawing all P&IDs.
We have already made many attempts to automate this, but with only moderate success.
The rework was so intensive that it was equal to the time we needed for the complete redraw, so we did not pursue automatic conversion any further.
If you have any questions, please do not hesitate to contact us.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Michiel.Valcke
Unfortunately there is no fast way to do this. There is the PIDCONVERT command, but this is still a component-by-component conversion. It does prevent you of having to delete and re-insert components.
In general, when confronted with 'living documents' You can create a project and copy all the AutoCAD drawings to the project. Then only when a sheet would need an update would the effort be made to convert the entire content of that sheet to P&ID objects. This way the monumental effort of having to convert tons of documents is spread over the lifetime of the project and the site. Offcourse this is not always doable and clients don't always want to hear this.
michelle_pintoEHV27
Thank you for your help anyway!
michelle_pintoEHV27
Thank you!
DVaquand
Hello
As @h_eger  and @Michiel.Valcke  say there is no quick way to convert.
However, to make your work easier and to avoid redoing a layout, it is possible to put in the background of the plan, under Xref, the DWG or PDF files on which you will rely to trace the P&ID.
This is the principle that I adopted to redo P&ID in Plant 3D
== French ==
Comme le disent @h_eger  et @Michiel.Valcke  il n'existe pas de moyen rapide de conversion.
Néanmoins, pour vous faciliter le travail et pour éviter de refaire une mise en page il est possible de mettre en fond de plan, sous Xref, le fichier DWG ou PDF sur lequel vous allez vous appuyer pour retracer le P&ID.
C'est le principe que j'avais adopté pour refaire des P&ID sous Plant 3D
Cordialement
Dominique VAQUAND
www.dovaq.fr
Si mon message propose une solution, veuillez cliquer sur "Accepter comme solution"
If my post offers a solution, please click "Accept as Solution"
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
michelle_pintoEHV27
Thanks! I will do it! I am new in the Auto Plant 3D, as my team too, so any tip is welcome!
