Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I recently create a mixproof vavle using python script and I want to change the orientation of the valve just by input the direction in part Geometry.
According to this article: https://knowledge.autodesk.com/support/autocad-plant-3d/learn-explore/caas/CloudHelp/cloudhelp/2018/... :
The Content Iso Symbol Definition must include TYPE=VALVE-MULTIWAY to set level angles in the properties palette. Most spec-based components to not allow you to change dimensions so this is a special case, which is enabled based on the TYPE.
I already tried but it didn't show up the part geometry.
I can define custom dimension with PLANTCUSTOMPARTS and insert after that but that's not what I want and the part geometry still didn't show up.
Please help me solve the problem.
Hoang Minh Quan - Lead Developer
Autodesk Store for IntegaDesign Content
Smart Solutions by IntegaDesign
Plant 3D • CAD Optimization • Automation
