Display part geometry for mixproof valve (python script component)
quan_hm
Message 1 of 8
quan_hm
I recently create a mixproof vavle using python script and I want to change the orientation of the valve just by input the direction in part Geometry.
According to this article: https://knowledge.autodesk.com/support/autocad-plant-3d/learn-explore/caas/CloudHelp/cloudhelp/2018/...  :
The Content Iso Symbol Definition must include TYPE=VALVE-MULTIWAY to set level angles in the properties palette. Most spec-based components to not allow you to change dimensions so this is a special case, which is enabled based on the TYPE.
I already tried but it didn't show up the part geometry.
I can define custom dimension with PLANTCUSTOMPARTS and insert after that but that's not what I want and the part geometry still didn't show up.
Please help me solve the problem.
Hoang Minh Quan - Piping design engineer
Autodesk Store for Python Catalog
Replies (7)
Message 2 of 8
quan_hm
Update, I tried to set the Component Designation in the spec to "Custom" and "Parametric".
Somes work:
But the valve still dont show the dimensions
Message 3 of 8
rajendra.prajapat
@quan_hm still it is not showing using the Component Designation property as custom?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Message 4 of 8
quan_hm
It's seem that if I set the valve to different class ("coupling" for example) then the part geometry can be preview and dimensions can be edited. Anyone know what's wrong with "valve" class?
Message 5 of 8
rajendra.prajapat
@quan_hm please use the class valvebody.
Message 6 of 8
quan_hm
I Created new valveBody component:
The className in database is also valveBody
But the geometry still didnt show up. Keep in mind that with the class = "valve" the default P3D parametric components is showing good. You have any suggestions? @rajendra.prajapat I'm very appreciated.
Message 7 of 8
quan_hm
Yes. I tried both "Custom" and "Parametric"
Message 8 of 8
quan_hm
I found the solusion. Just named your valve something like CPVF000000_Y with CPVF000000 is the existing default valve (many others name you can choose) and _Y is your custom valve name. The software will understand that this is parametric valve and allow you to edit it.
