AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
centrifugal pump side suction top discahrge dimension issue
5 REPLIES 5
kumarswapan64
1565 Views, 5 Replies
In Create Template "Centrifugal Pump" side suction Top discharge there is no parameter for the dimension of cl. of suction to Top of discharge flange.
please help me to create the pump model.
Swapan Kumar
5 REPLIES 5
Can you send us your model for further investigation at our end.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
please provide me your e-mail id. files are not being attached with this message.
Swapan Kumar
Please see the below image of Centrifugal Pump.
Centrifugal Pump
Swapan Kumar
When you edit the nozzle once placed, you are presented with the height of the nozzle. Its not in that dialog box, its in the Edit Nozzle dialog.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
cadPNYBN
in reply to: kumarswapan64
The title of this forum post is "side suction top discahrge" but nowhere is a side suction pump nozzle mentioned, it is an end suction.
As far as I can tell, Plant 3D cannot create a side-suction centrifugal pump from the parametric equipment builder.
