pipe/fittings ignoring custom valve ports and instead connecting to center
Have added several downloaded 2 way valves into P3d with no issues. Following the same process with a 3 way, downloaded geometry, converted to plant3d part, set all 3 port locations and added to catalogue and spec.
Valve inserts well, the issue is, instead of connecting to the assigned ports as with the other valves, all of the pipe/fittings attach to the center point of the valve.
As far as I can tell, I've done nothing different to this valve from the 2 ways that I've successfully imported. I've not found this exact situation via searches so far. Any ideas?
Link copied
