In Create Template "Centrifugal Pump" side suction Top discharge there is no parameter for the dimension of cl. of suction to Top of discharge flange.
please help me to create the pump model.
Solved by TomislavGolubovic. Go to Solution.
Can you send us your model for further investigation at our end.
please provide me your e-mail id. files are not being attached with this message.
When you edit the nozzle once placed, you are presented with the height of the nozzle. Its not in that dialog box, its in the Edit Nozzle dialog.
The title of this forum post is "side suction top discahrge" but nowhere is a side suction pump nozzle mentioned, it is an end suction.
As far as I can tell, Plant 3D cannot create a side-suction centrifugal pump from the parametric equipment builder.
