AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Bring main Dimension on top
1 REPLY 1
rafimh2022
76 Views, 1 Reply
Hi All,
Is there is any way to interchange the dimension location ? For example here I attached an image file. here the main dimension line is on bottom and detailed dimension line is on top side and its overlapping. So is there is any setting to fix this issue without manual editing?
Thanks & Regards,
Rafi.
1 REPLY 1
Michiel.Valcke
in reply to: rafimh2022
that is weird, end-to-end dimensions are normally by default placed above string and locating dimensions.
Can you share your .pcf file and isoconfig.xml?
Also definitely check your default dimension settings for the affected theme.
Technology Administrators
AutoCAD Beta
