Tried version :
M046.2502 Autodesk AutoCAD Plant 3D 2019.2.1 Update
M047.02 Autodesk AutoCAD Plant 3D 2020
P3D_S051.02 AutoCAD Plant 3D 2022
T05302.1 Autodesk AutoCAD Plant 3D 2023.0.2
Why does it seem like the pipe is cut at the tap weld section when placing an olet and an eccentric reducer on the same line in an isometric drawing?
The same issue occurs in tested Plant3D versions.
Is there a solution to this issue?
Link copied
