Hello All,
I created following fitting and valve in plant 3d but in isos only the fitting is appeared and I cant see valve symbol.
Thanks and regards,
Rafi.
Pls upload your drawing here to check in more detail
How do you think we should solve your problem?
We have no information at all about how you created this valve and with which
Iso Symbol Type:
and
Iso Symbol SKEY
then we would use the PCF file (change file extension to *.txt)
and any other information that would allow us to help you!
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Hi Sir Quan hm,
Thanks for your quick response and time. I already solve this issue by changing the SKEY value in xml file, but still am looking for a solution to show the valve operator direction in ISOS for each valves.
Rafi.
did you also create your Valve as ValveBody in the Speceditor?
and the hand lever as actuator
and last but not least, the ValveBody married to the Actuator via the Edit Operator Assigments function?
Hartmut Eger
Senior Engineer
XING | LinkedIn
Hello @rafimh2022
What SKEY code have you assigned to your valve ?
How does the valve come out in the iso ?
== French ==
Quel code SKEY avez-vous affecté à votre vanne ?
Comment sort la vanne dans l'iso ?
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
