Dear @Andrew_Root,
this feature is not supported by AutoCAD Plant 3D and BIM projects!
Please contact trustworthy company Autodesk !!! ;-(
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
@Andrew_Root I was able to edit the Iso template and add attributes using the project setup. I might not be using the same workflow you are using but here is an Autodesk Screencast I created that shows the workflow I used.
AutoCAD Plant 3D Collaboration adding attributes to an Iso template
Quentin Contreras
Technical Support Specialist
