AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Using elevation grip turns off polar
4 REPLIES 4
342 Views, 4 Replies
I use polar tracking for all my angle needs but when using the elevation grip on piping it turns on orthomode, which is fine but when the command is finished it doesn't turn polar tracking back on.
This has been an issue across many versions and I think I originally reported it back in the 2014 version.
It would be good for it to remember whether polar was active before and restore that setting after.
Scott
Scott
4 REPLIES 4
VinodBalasubramanian
Autodesk Support
Autodesk Support
Can i know what is the value for DYNMODE and also send me a screenshot of your OSNAP settings.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
in reply to: VinodBalasubramanian
DYNMODE is -3.
OSMODE is 4159 (the first 8 except geometric center)
DYNMODE is -3.
Autodesk Support
Autodesk Support
Thanks for the info. Can you try the suggestions here,
http://knowledge.autodesk.com/article/3D-objects-are-offset-from-object-grips-after-you-reopen-the-f...
Hope it helps to fix your issue.
I tried the link. The link however is talking about display issues and didn't work.
The issue is having polar tracking on when using a elevation grip on a piece of pipe, which will result in ortho turning on and polar turning off and once the command is finished ortho turning off but polar not turning back on.
When using the elevation grip it needs to record whether polar was active prior to the command starting and reinstate it after completion.
This has been around for a while, not just 2018.
