AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Adding Title Block Attribute in BIM Team Project
2 REPLIES 2
Andrew_Root
286 Views, 2 Replies
Andrew_Root
When we try to edit an ISO title block template in our BIM Team project, using the Project Config, we are able to place the attribute and save and close the template, but when we try to check in the update setting change, it shows a caution triangle in the BIM Team project icon (in Plant 3D application), which basically means that setting change did not take place. We then have to close then check in settings (does not work), open project again then check in settings (does not work), close the project and check in settings (finally works, but does not check in the updated settings, but the settings previous to making the change. What is the proper way to update this type of a change in a BIM Team project? When doing this change in a SQL project, everything works as expected the first time. Thank you!
2 REPLIES 2
h_eger
in reply to: Andrew_Root
h_eger
Dear @Andrew_Root,
this feature is not supported by AutoCAD Plant 3D and BIM projects!
Please contact trustworthy company Autodesk !!!  ;-(
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Dear @Andrew_Root,
Hartmut Eger
Senior Engineer
XING | LinkedIn
quentin.contreras
Autodesk Support
Autodesk Support
@Andrew_Root I was able to edit the Iso template and add attributes using the project setup. I might not be using the same workflow you are using but here is an Autodesk Screencast I created that shows the workflow I used.
AutoCAD Plant 3D Collaboration adding attributes to an Iso template
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
Quentin Contreras
