Are 'Output settings' no longer changeable in web app?
I know I'm replying to something that's 6 years old.. but is the "output setting" no longer changeable?
I am experiencing the same issues as the original post - PDF is not centered and is not to scale.
@Anonymous
Reply has been made a very own topic and title adjusted by @Tarek_K
acadhelp1
engineary,
Currently, you are not able to select a plot style or deeply configure the PDF output.
Output from a layout will match the settings in the drawing
Output from Modelspace has some minor configurations.
Take a look at this help page: https://help.autodesk.com/view/ACADWEB/ENU/?guid=AutoCAD_Web_Help_Plottopdf_html
I hope this helps,
Jon
Jon Page
AutoCAD Design Manager
Thomas_Stuehle
Hello @Anonymous
could the information provided by @acadhelp1  help you and answer your question?
Otherwise I recommend to plot via layout. I just ran a test on my side - the result is as expected when you plot a layout.
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information. If not please don't hesitate to give an update here in your topic so all members know what´s the progression on your question is and can suggest next steps that might be helpful for you to achieve what you´re looking for.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
Thomas_Stuehle
Hello @Anonymous
did the plot via layout work for you and exported the PDF correctly?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information. If not please dont hesitate to give an update here in your topic so all members know what´s the progression on your question is and can suggest next steps that might be helpful for you to achieve what you´re looking for.
Best regards,
Thomas
Thomas Stühle
Hi Jon,
Thanks for the info!  I have tried plotting via Layout, but I am unable to modify the Paper Size.  Could this be a browser issue?  I have tried in both Chrome and Microsoft Edge, but some options are just not click-able.
Where would I get to the Layout Properties?  I feel like I've right-clicked everywhere possible.
Thomas_Stuehle
Hello @Anonymous
the command PAGESETUP is not available in the AutoCAD Web App.
When you create a new drawing in the AutoCAD Web App, the Layout1 and Layout2 are created as a
  • ISO A4 (210.00 x 297.00 MM) Landscape
Since changing the Page Setup is a limitation in the Web Application, I would recommend the following steps in combination with AutoCAD Desktop (if possible for you):
Saved at Web & Mobile
1. Open AutoCAD Desktop
2. Open the drawing from within your AutoCAD Dekstop Application with OPENFROMWEBMOBILE
3. Change the Page Setup via the command PAGESETUP
4. Use the command SAVETOWEBMOBILE to save your drawing again
5. Open the drawing in the Web Application and plot again with the new page setup.
Saved on an external storage provider
2. Open the drawing from your external storage provider
4. Save your drawing
Did the post helped you and answered your question? If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Best regards,
Thomas
Thomas Stühle
Thanks Tom!
Unfortunately, I created this drawing wholly within the web interface, and therefore could not edit the paper size for layout.  However, your answer appears to be the correct solution, so I am marking it as such.  Thanks!
