Hello @Anonymous
the command PAGESETUP is not available in the AutoCAD Web App.
When you create a new drawing in the AutoCAD Web App, the Layout1 and Layout2 are created as a
- ISO A4 (210.00 x 297.00 MM) Landscape
Since changing the Page Setup is a limitation in the Web Application, I would recommend the following steps in combination with AutoCAD Desktop (if possible for you):
Saved at Web & Mobile
1. Open AutoCAD Desktop
2. Open the drawing from within your AutoCAD Dekstop Application with OPENFROMWEBMOBILE
3. Change the Page Setup via the command PAGESETUP
4. Use the command SAVETOWEBMOBILE to save your drawing again
5. Open the drawing in the Web Application and plot again with the new page setup.
Saved on an external storage provider
2. Open the drawing from your external storage provider
4. Save your drawing
Did the post helped you and answered your question? If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
