file error wile saving
Berrys_Cooling_Drafter
all my files are saving and showing that there was an error while saving and needs a recovery can anybody help me to figure out why all my files are needed recovery and what I can do to stop this from happening again
pendean
Community Legend
Community Legend
Your year version is...?
Did a newer year verson touch your files by chance? Or did you change hardware or file locations? Something changed bud, what is it? Find out if you don't know.
HOW CAN I FIND OUT this INFORMATION?
Tiana_Y
Hi @Berrys_Cooling_Drafter
If you have been the only one using your files, what versions do you use or have been using to open the files? As far as the hardware or file location, I believe that he is asking if you have saved the files in any new locations that might have settings that differ from where they once were located. There is also a chance that the file itself is corrupted, this AKN article has the steps to run PURGE, AUDIT and -PURGE on the file and then how to WBLOCK it into a new clean file. Hope this helps!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Tiana.D
Community Program Manager
Contact Autodesk Support
Tiana_Y
I'm just checking in to see if you need more help with this. Did the suggestion that I provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Tiana.D
