dimension text mirrored
Berrys_Cooling_Drafter
Message 1 of 10
see attached can someone tell me why this is happening does it have to do with what these pics are showing and how do I change it                                                 whats up.JPGCapture.JPGCapture2.JPG
Replies (9)
Message 2 of 10
pendean
Community Legend
Community Legend
You are looking at your model from the bottom... . That should read "top".
Message 3 of 10
Tiana_Y
Hi @Berrys_Cooling_Drafter
Did the suggestion @pendean give you help?
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Tiana.D
Community Program Manager
Contact Autodesk Support
Message 4 of 10
HOW DO YOU CHANGE THAT
Message 5 of 10
I STILL DIDNT GET A GOOD ENOUGH ANSWER
Message 6 of 10
Tiana_Y
You're Navigation Cube appears that it is viewing from the bottom, if you change the view to Top, does it help the dimensions? This AKN article shows you all the ways you can navigate the Nav Cube.
Hope this clear things up a bit!
Tiana.D
Message 7 of 10
pendean
Community Legend
Community Legend
Message 8 of 10
Tiana_Y
Hi @Berrys_Cooling_Drafter,
Did the clarification both myself and @pendean provide help?
Tiana.D
Message 9 of 10
it does not help when i choose top view
Message 10 of 10
Tiana_Y
If you change the UCS to World and then select the Top view does that help? If you have a custom UCS, save that before changing.
Tiana.D
