OSNAP modes still snapping after disabled
I recently installed Acad Mechanical 2018 and am getting error in using osnap as desired. The default setting had endpoint, midpoint, intersection, node selections checked and when I uncheck all of them but atleast one (for instance node), it doesn't take effect. It still snaps to all pre selected osnaps even though the osnap settings menu shows only the node selection checked. Kindly advise if there is a solution to solve this issue/error.
sarora
[The subject line of this post has been edited for clarity by cheryl.buck from: Osnap settings error]
gaurav.satalkar
Can you please check if the Sysvar OSNAPOVERRIDE is set to 1? If is 1, please change it to 0.
Also please check the OSMODE System variable.
This should allow you to change your default OSNAP settings.
Hope this helps.
Thank You,
Gaurav Satalkar
QA Engineer
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD Mechanical forum. Welcome to the Autodesk Community!
I am checking back to see if you were able to resolve your issue or if the great post by @gaurav.satalkar helped you with your problem.
Additionally, if you have not done so already, please install the latest AutoCAD Mechanical updates. All current updates are available through your Autodesk Account under the Manage tab
All the best,
If a post was helpful, Kudos are always welcome.
Please also select the Accept as Solution button on any posts that helped solve your issue or answered your question.
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Hi Cheryl,
The issue has been resolved due to the following users post in the forum.
Osnap settings turning off
Many Thanks to 'pchabot' for posting the same in the forum. Although I would still like to know how to cycle through the various user settings (4 in total) stored in the Power snap configurations as per attached.
SA
[This post has been edited for clarity with a link for the referenced forum thread by cheryl.buck]
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank your for the information on how you solved your problem. On your follow up question, I do not know of a way to cycle through the Power Snap Global Configurations. I believe the only way to change that is through the AMPOWERSNAPS dialog box.
However, another user may well have written a LISP routine for this. You could ask in the AutoCAD Customizations forum for LISP.
All the best,
Cheryl Buck
