AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
How to insert my own block with a leader
13 REPLIES 13
Message 1 of 14
1115 Views, 13 Replies
Hello everyone
I created very simple block with 1 atribute (text). How can I put it to the symbols menu to make it possible to insert it with a leader?
13 REPLIES 13
Message 2 of 14
Sridhar-Autodesk
Hi
You cannot add a block to AMNOTE gallery.  Amnote can be used with a text information.  If you would like to add custom templates, command: AMNOTE>> Pick 2 points>>Enter the text info>>In the Ribbon>>Library Dropdown>>Select "Add Template"
For blocks; once you create a block, the block can be seen in Block Gallery.  Switch to Insert Tab>>Block Panel>>Insert Dropdown to see the list of blocks created.
Sridhar Subramani
Senior Product Owner
Message 3 of 14
in reply to: Sridhar-Autodesk
Thank you for the answer. It helps me a little but it still isn't what I'am looking for.
Simply I want to put my block with atributes (no matter it is block, symbol or however it is called in Autocad Mechanical) with a leader arrow. In "normal" Autocad I could create new multileader style, change it's type to block and choose user block. How can I achieve the same result in Autocad Mechanical?
Message 4 of 14
cheryl.buck
Hi @Anonymous,
I believe the command you are looking for is MLEADERSTYLE which brings up this dialog window:
Please let me know.
All the best.
If my post was helpful, Kudos are always welcome.
And if it answered your question or solved your problem, please select the Accept as Solution button.
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Message 5 of 14
in reply to: cheryl.buck
Unfortunately in Autocad Mechanical command MLEADERSTYLE doesn't exist. There is only some system variable CMLEADERSTYLE. Any ideas?
Message 6 of 14
cheryl.buck
Hi @Anonymous,
I have MLEADERSTYLE in AutoCAD versions 2015 through 2018. Which version are you working with? Have you installed the updates?
All current updates are available through your Autodesk Account.
All the best,
Cheryl Buck
Message 7 of 14
cheryl.buck
Hi @Anonymous,
I am checking back to see if my post helped you with your problem.
All the best,
Cheryl Buck
Message 8 of 14
Hi. Sorry for answering so late. I am busy recently.
I use Autocad Mechanical 2017 but Polish version. The problem was that I forgot to type "_" before the command MLEADERSTYLE. This dialog box shows up, but another problem occurs. I am not able to choose the block I created. It isn't on the list. I'm sure it is created because it is in the insert panel. Maybe I ommited something while creating block in block editor. The only thing I added was base point. Maybe some other thing need to be added in block editor to make this block to be listed in mleaderstyle dialog box.
Message 9 of 14
I would like o refresh the topic. Anyone knows how to do this?
Message 10 of 14
cheryl.buck
Hi @Anonymous,
I apologize for the delay in response, I was away for a few days. I did run some tests, and was not able to see the block that contained only a point either. Once I added some geometric content, I was able to select my block. It seems as though there must be some geometric or textual content in the block for it to be used to create a custom MLEADER
There seem to be some difference between the Polish and English versions. The dialog box you are showing for _MLEADERSTYLE is accessed in the English version from the Modify option of MLEADERSTYLE.
All the best,
[This post has been edited for clarity by cheryl.buck]
Cheryl Buck
Message 11 of 14
cheryl.buck
Hi @Anonymous,
I am checking back to see if you have been able to create your custom MLEADER.
All the best,
Cheryl Buck
Message 12 of 14
cheryl.buck
Hi @Anonymous,
I apologize for coming back to this late. I have been looking into the issue further and found that Annotative blocks are not shown in the list. This is explained in the in application help file "About Mleader Styles".  It can be checked by opening the Properties Palette, type the command PROPERTIES (or CH), under the section labeled Misc, if check that Annotative is set to No
If Annotative is set to Yes, edit the block (BEDIT) and change Annotative to No then save the block. it should show up in the list after that.
Please let me know if this helped.
All the best,
Cheryl Buck
Message 13 of 14
Thank you @cheryl.buck
Your clues were essential and I finally found out how to do this in Autocad Mechanical (Polish version)
Here is summary what need to be done:
  • Create in scale 1:1 (text height 3,5 in my case) atribute and block (both not annotative).
  • Create new leader style using command _mleaderstyle, set type to block and choose user block created earlier. Set it's scale to 1.
  • Set desired scale of a leader using command _mleaderscale.
  • Insert our block with the leader using command _mleader.
Message 14 of 14
cheryl.buck
Hi @Anonymous,
I'm really glad you were able to create the custom MLEADER. Thank you coming back and posting, I have awarded you Kudos for sharing the details of your solution.
I look forward to seeing you in the AutoCAD Mechanical Forums in the future.
All the best,
Cheryl Buck
Technology Administrators
AutoCAD Beta
