Exporting Object Data to excel.
I would like to see a simpler way of extracting or exporting Object data or attribution (on GIS language...) to an excel file without having to export everything as shape and then having to import again etc. Kind of the same way a table is generated when we connect to a shape file instead of going the MAPIMPORT route.
We are constantly going from one system to the other and as a CAD specialist I was challenge with that question from a GIS specialist the other day. We try several ways but it took a long time and a lot of importing exporting extracting etc.
Is there a way to create a tool that will extract OD into excel? Civli 3d has a similar tool for parcel information etc.
2 Comments
 I agree! Obviously, a simple, fast export of OD to Excel (csv) is needed.
Therefore, we made ODEDIT export OD to csv, but it is not in the demo version.
Exporting from OD into csv data in the form of explications would also be useful.
But! For the sake of justice!
In Map 3D, you can create reports in queries to connected files as txt with delimiters ";" is actually csv.
I did not understand his logic to the end, but perhaps this is a sufficient tool ...
We have done in the demo version of ODEDIT the export of Object Data to csv with the addition of calculation by values in the key field - ODEDIT_EXPL.
In the first field, the graphical elements handle are saved.
