Workspace - default
Workspace - default
kellymg
Message 1 of 23
Workspace - default
kellymg
Hello! I have installed the 2012 Map software. I have selected the workspace that i want to use until 2013 is released Smiley Happy I went to the workspace customization settings, and selected my favorite workspace as the default & current. I apply/ok to leave customization dialog box. When i close out of the program entirely, and re-open the software, a different workspace is loaded during startup. How do i change my favorite workspace to automatically open during startup? Thank for your advice everyone
Replies (22)
Message 21 of 23
Murph_Map
@Anonymous wrote:
hey murphy,
how's things in TN?
I set the workspaqce like that, moved my cutomized ws to the top of the list, but every time I open Map it opens with the c3d workspace. this is problmeatic, since if i want to use c3d i will open it, and i'm getting question marks and unknown commands from c3d toolbars that open by default with the c3d workspace.
this is win7 w/adesk 2016 Infrastructure Design Suite. no sp's, i cannot install them. don't ask, it is a very long and frustrating story.
david
expert microstation user not by choice since 2014
David,
After you set it all up again the way you want make sure you do a save current workspace.
As far as TN is, it's still here 🙂
You don't pop in on Owens server anymore?
Murph
Supporting the troops daily.
Message 22 of 23
svsplayer
Make A LISP file :
(if s::startup
 (setq s::startup (append s::startup (command "WSCURRENT" "SebMap")))
 (defun s::startup () (command "WSCURRENT" "SebMap"))
Instead of SebMap enter your saved name workspace as you configured.
Next , make sure you appload that lisp (automatically of course) , avery time you open Autocad .
Message 23 of 23
svsplayer
Make A LISP file :
(if s::startup
Next , make sure you appload that lisp (automatically of course) , avery time you open Autocad .Workspace_solved.jpg
