Change properties of a PLGRIDSYSTEM
ericdaniel
Message 1 of 9
ericdaniel
Is it possible to change the color, linetype, etc of a PLGRIDSYSTEM in Map 3D 2012?
Eric
Replies (8)
Message 2 of 9
Hi! Any luck with it?
I also don't like it shows coordinates around viewport. I would rather keep them within.
Message 3 of 9
Yes,
using MAPLOADGRIDSTYLE you can load a xml file with the properties.
I found it on this site how to do it
http://beingcivil.typepad.com/my_weblog/2011/08/making-your-layout-look-more-like-a-topo-1.html
Attached is my xml file so you can edit the properties.
Eric
Message 4 of 9
Thanks! That is really helpful.
Message 5 of 9
anatolyn
It' ok,but after ucs changed all side text jumped-(
Message 6 of 9
I guess that it's impossible to avoid that. I suggest to do coordinate grid at the very end or repeat procedure.
Cheers,
Vasily
Message 7 of 9
anatolyn
Thanks for ansver
We are working in this standard(see pic)
 Do you have similar xml or how you can make this?
Message 8 of 9
I know this was years ago, but any chance you're still around to answer a question about your xml file......
Not having coordinate text show up every time I use it.  Looking for an increment setting but having no luck.
Thanks in advance.
Message 9 of 9
Hi could you re post your XML file please?
Thankyou in advance
Maurizio
