Map 3D commands problem and reinstallation- after Mapclean repeat command
JC-OUAKNINE2
JC-OUAKNINE2
Hello every one,
I had this morning a problem on my main laptop (with Map3D 2020-2021 & Civil 3D 2020-2021).
I run the Mapclean command on Map3D 2020 to snap luster nodes (with polylines and blocks).
At the end of a clean up, I re-run very quickly with space button > no dialog box for Mapclean appears !
More, some commands such as Mapexport show dialog box, but without any option to select objects, options, etc...
More, FOR all my vertical products Map3D & Civil 3D, Mapclean and Mapexport don't run correctly.
At last, I have unsictall/reinstall all those Map-based products !
During this time, I have used a second laptop with same softwares installed.
I have run Mapclean functions on Map3D 2019 during many hours.
Until I re-run too quicly with space button to launche again Mapclean,
and same result: no dialog box for Mapclean apperas, error with Mapexport Command, etc ...
on all MAp-based products of this second laptop.
Any idea or solution for this problem ?
Jean-Christophe OUAKNINE
JC-OUAKNINE2
Once again, on my main laptop repaired
after clean unstall and reinstall of all my based-map products,
with all service packs and updates
I ran again maclean command
and againg after a space button action to repeat action,
MAPCLEAN MAPEXPORT dosn't recognize on all my based-map products.
I unsitall all those products, and reisntall only Map3D 2020 to continue my job...
For information,I open a case with the Autodesk Support.
JC-OUAKNINE2
Hi every one,
I found the solution:
on the second PC where commands as MAPEXPORT MAPCLEAN ... don't work
I didn't reinstall any MAP-based softwar
but I just kill register key AutoCAD MAP dialog extension
see file attached
braudpat
Hello @JC-OUAKNINE2
BRAVO & Felicitations Mr Sherlock Holmes !!
THE HEALTH (Stay Safe, Stay Home, Stay Live), Regards, Patrice (The Retired Old French EE Froggy)
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
JC-OUAKNINE2
Merci Grand Maître!
Yami72
Thank you jcouaknine! You saved my day!
