How to create a solid from polyines?
john_daues
john_daues
I need to create a solid from the polylines. Referring to the attached, the solid should have a hole in the middle (like a donut) and then tapers out to the edge.
Can some outline the steps to do this?
Alfred.NESWADBA
you can run 3 times command _LOFT
1= from outer spline to upper circle
2= from upper circle to lower circle
3= from lower circle to outer spline
Then run command _UNION with these 3 surfaces.
At least run command _CONVTOSOLID to convert the surface to a 3D-Solid.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john_daues
Thanks for your reply. I am following your steps but I must be doing something wrong. I do the first loft command as you specify, then I do the second. However, with this second command the hole appears to be filled in, i.e. not like a donut. (see attached)
What can you suggest?
Alfred.NESWADBA
please find this video showing the steps I'm going.
It might be helpful to have SELECTIONCYCLING activated to really know which of the selected objects are used.
- alfred -
Alfred NESWADBA
john_daues
Thanks! I have it now.
Now I use the command massprop and it shows:
---------------- SOLIDS ----------------
Mass: 1444.0888
Volume: 1444.0888
What are the units? I think it is cubic feet.  Where do I see/set this?
Alfred.NESWADBA
>> What are the units?
This question can only be answered by yourselves as only you know which units where used to create the basic geometry. The result of _MASSPROP uses the same units used for the current objects.
- alfred -
Alfred NESWADBA
