AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
lines that I draw in straight Autocad don't show up when I open in Map3d
10 REPLIES 10
Message 1 of 11
MKH-VB
593 Views, 10 Replies
as my title shows, I have been drawings some water lines in as polylines in autocad.  I have opened up this file in Map 3d, and I see these lines "flash" as the drawing opens, but then they are gone.  Any idea what could be going on with this?
mkh
10 REPLIES 10
Message 2 of 11
Pointdump
in reply to: MKH-VB
Hi Mike,
Can you post the drawing?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 3 of 11
MKH-VB
in reply to: Pointdump
here's the drawing...it is referencing a few shp files that i did not include.
mkh
Message 4 of 11
Pointdump
in reply to: MKH-VB
Mike,
Thanks for posting your drawing. I get pretty much the same as you, now you see 'um, now you don't. Other than a record number of errors when I used RECOVER to open the drawing, and a missing Xref, I don't see anything obvious.
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 11
Valentin-WSP
in reply to: MKH-VB
@MKH-VB ,
The drawing seems to be corrupted.
Consider this link:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
Message 6 of 11
pendean
in reply to: MKH-VB
RECOVER your FILE, QSAVE then WBLOCK your PLINEs to a new file and see if your issue goes away in that new file.
or redraw those PLINEs in M3D as a last resort.
Message 7 of 11
Pointdump
in reply to: pendean
Dean,
"RECOVER your FILE, QSAVE then WBLOCK your PLINEs to a new file..."
That's the problem. There's nothing in the drawing, even though QSELECT shows 3439 items.
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 11
Pointdump
in reply to: MKH-VB
Mike,
Try clicking "Map Base".
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 11
MKH-VB
Holy Crap! Where did that check box come from? 🙂
mkh
Message 10 of 11
ChicagoLooper
in reply to: MKH-VB
Totally agree with @Pointdump
The Map Base hosts the vanilla AutoCAD objects. The Map Task Pane 'layers' above it (the ones with the yellow triangles) are layers brought in using an FDO connection. Unchecking Map Base will only leave you with Data Layers with valid connections..
Chicagolooper
Message 11 of 11
MKH-VB
in reply to: ChicagoLooper
very cool! I have learned something today. Thanks very much
mkh
