as my title shows, I have been drawings some water lines in as polylines in autocad. I have opened up this file in Map 3d, and I see these lines "flash" as the drawing opens, but then they are gone. Any idea what could be going on with this?
Solved by Pointdump. Go to Solution.
Hi Mike,
Can you post the drawing?
Dave
Dave Stoll
Las Vegas, Nevada
Mike,
Thanks for posting your drawing. I get pretty much the same as you, now you see 'um, now you don't. Other than a record number of errors when I used RECOVER to open the drawing, and a missing Xref, I don't see anything obvious.
Dave
Dave Stoll
Las Vegas, Nevada
@MKH-VB ,
The drawing seems to be corrupted.
Consider this link:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Dean,
"RECOVER your FILE, QSAVE then WBLOCK your PLINEs to a new file..."
That's the problem. There's nothing in the drawing, even though QSELECT shows 3439 items.
Dave
Dave Stoll
Las Vegas, Nevada
Mike,
Try clicking "Map Base".
Dave
Dave Stoll
Las Vegas, Nevada
Totally agree with @Pointdump
The Map Base hosts the vanilla AutoCAD objects. The Map Task Pane 'layers' above it (the ones with the yellow triangles) are layers brought in using an FDO connection. Unchecking Map Base will only leave you with Data Layers with valid connections..
Chicagolooper
