How do I show Lat and Long from a point and use insert field command.
bbasan675XZ
bbasan675XZ
I am trying to use insert field command to display Lat and Long. I am using ILLIMAP from the CS Library. I changes the Datum to WGS84. It is still giving me Northing and eastling coordinates.
Pointdump
Hi @bbasan675XZ,
Welcome to the Autodesk Forums.
"...insert field command..."
Details please on what command you're using.
You don't need to create a custom coordinate system to use data in ILLIMAP coordinate system. Map 3D will very easily transform. What type of data do you have, AutoCAD objects or shapefile data?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
bbasan675XZ
I am going into insert field-Objects-Position_Decimal. I select the point first. I also tried systemvariable-Latatude-Decimal. I am trying to put points along a line and have the Lat and Long displayed.
Pointdump
@bbasan675XZ,
I'm not sure you can use an AutoCAD field to label Lats and Longs. I might be wrong. Vanilla AutoCAD and Map 3D are usually not on speaking terms.
Suggest a new workflow. After placing points along the line, use MAPEXPORT to create a point shapefile. Drag-n-Drop it back into your drawing and you can use a Feature Label Style to label with Lats and Longs.
Dave
Dave Stoll
Las Vegas, Nevada
Pointdump
@bbasan675XZ,
Some good ways >>>Here<<<.
Dave
Dave Stoll
Las Vegas, Nevada
ChicagoLooper
Hello @bbasan675XZ
Here's a workflow that works if you have a few points. It's easy to enter a few points one-by-one. However, if you have 74 points, you'll need a more efficient way to insert them.
<<For a long list of Lat/Long points, you can enter them in Map3D using an Excel spreadsheet. Entering Lat/Longs from a properly formatted spreadsheet is not covered in this post. If you want that procedure, please start a new post and a separate set of instructions will be provided.>>
To begin open a clean, brand new imperial template (not metric) and assign one of these coordinate systems: IL83-EF or IL83-WF. Which one you choose will depend on the County where your site is located. <<This exercise uses IL83-EF (EPSG 3435). Assign the appropriate coordinate system before beginning the steps shown below.>>
  1. Go Geolocation Tab=>Tools Panel=>Mark Position Dropdown=>Lat-Long Icon.
  2. On command line type in 41.891863=>ENTER for Latitude. On command line type in -87.605102 for Longitude=>ENTER
  3. At your cursor which is now flashing in modelspace, type in 'MyPoint' (or another ID label) then left-click a BLANK area in modelspace to insert your geomarker and end the GEOMARKLATLONG command.
  4. Select the geomarker you just created=>Go to Properties Palette=>Change size to 200 (you can increase/decrease size later). This geomarker's Lat and Long will be displayed at the bottom of the Properties Palette. The x/y values are referenced to Illinois State Plane coordinates, NAD83, East Zone, Feet (EPSG 3435) and will also be displayed in the Prop Palette under the Geometry Section. (The position-x and position-y value always adopts or inherits the units of the assigned coordinate system.)
  5. OPTIONAL: If you want higher precision in your Lat/Long coordinates, then enter UNITS on command line=>Change precision to 6-decimal places.
Step-1Step-1
Step-2Step-2
Step-3Step-3
Step-4Step-4
Step-5Step-5
Finally, you can turn on Bing Hybrid for an aerial photo background. If you have performed this exercise using IL83-EF coordinate system and entered the same Lat/Long shown above, then your geomarker will be positioned at Navy Pier.
Chicagolooper
