Help on File (SQLite DWG) based Industry Models : Copy the FID Field ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello
Please help me ...
I would like to copy the famous Integer Field FID which is created / generated on all SQLite Tables by the Industry Models
So I need an Utility (DLL, ARX, Script, etc) which run on File (SQLite DWG) based Industry Models
It will create a NEW Integer Field named FID_COPY and copy the original FID into it ...
It must run on ALL SQLite Tables of the Project (which are inside the DWG) ...
Thanks in advance, Bye, Pat (The Old French EE Froggy)
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
