Hello
Please help me ...
I would like to copy the famous Integer Field FID which is created / generated on all SQLite Tables by the Industry Models
So I need an Utility (DLL, ARX, Script, etc) which run on File (SQLite DWG) based Industry Models
It will create a NEW Integer Field named FID_COPY and copy the original FID into it ...
It must run on ALL SQLite Tables of the Project (which are inside the DWG) ...
Thanks in advance, Bye, Pat (The Old French EE Froggy)
Patrice BRAUD
Hi @braudpat ,
With IM Editor, you can open your DWG, add a field to your base, edit form to add this new field, and then Export Excel Direct, update new column by copy/paste into excel, and then Import Excel direct.
The workflow should work, even if it doesn't on my Map 2024 ![]()
Olivier Eckmann
Hello @O_Eckmann
YES but I have many tables (20-60) per SQLite DWG and many DWGs ...
So a Tool would be Nice to run inside a SQLite DWG
Bye, Pat
Patrice BRAUD
