Can I script a BATCHPLOT through the command line or windows scheduler?
tmblackflag
tmblackflag
I've set up an intricate BATCHPLOT that works well but needs to be kicked off manually. Is there a way to schedule and run this job?
pendean
Community Legend
Community Legend
If you use the actual command name (see snip from HELP) that may be enough to get you started with your commandline needs
