AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Can I script a BATCHPLOT through the command line or windows scheduler?
1 ANTWORT 1
Nachricht 1 von 2
tmblackflag
95 Aufrufe, 1 Antwort
I've set up an intricate BATCHPLOT that works well but needs to be kicked off manually. Is there a way to schedule and run this job?
1 ANTWORT 1
Nachricht 2 von 2
pendean
als Antwort auf: tmblackflag
If you use the actual command name (see snip from HELP) that may be enough to get you started with your commandline needs
