FEMA WMS server connection - not connecting
dean.borcik
dean.borcik
All,
I am using C3D 2025 going thru the "Planning and Analysis" tab trying to connect to FEMA WMS server and having issues not connecting. I have tried two different links from their website with no success.
The links are:
https://hazards.fema.gov/wmsconnector/wmsconnector/Servlet/flood?REQUEST=GetCapabilities&SERVICE=WMS
and
I copied and pasted each separately and hit the "Connect" button with nothing happening.
Any advice???
Thank you
Dean Borcik
Pointdump
Hi Dean,
I'm getting "failed to connect" with both URL's you posted.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
CodeDing
@dean.borcik ,
Their WMS link is provided toward the bottom of this page here:
https://hazards.fema.gov/femaportal/wps/portal/NFHLWMS
However, the WMS link does not appear to be working (maybe I'm not versed enough to test it properly). I did test the WFS link and it is working though, so you might have to use that for now.
Best,
~DD
CodeDing
@dean.borcik ,
Actually, I just got it. The link had to be very specific:
https://hazards.fema.gov/arcgis/services/public/NFHLWMS/MapServer/WMSServer?
(I used the 1.3.0 for "Version", not sure if that matters or if default would work)
Best,
~DD
ChicagoLooper
Hi @dean.borcik
Yes, you can make a 'connection' but you can't connect to the data you want.
1. Go to the FEMA page then scroll all the way to the bottom.
Image-1Image-1
2. Copy the highlight address and paste it in the Add WMS Connection of the Data Connect Palette.
Image-2Image-2
3.When you're connected, be sure to check the box at the bottom. It's the only layer(?) that can be added.
<<How ironical. It's named NFHL Availability>> LOL
Image-3Image-3
Is the WMS connection giving you anything?
Chicagolooper
