AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Export multiple styles (created from thematic rules) to AutoCAD blocks
8 REPLIES 8
Message 1 of 9
Simon_Thouin-Verdun
625 Views, 8 Replies
I've created multiple thematic rules with each a different style and I was wondering if it's possible to export them as blocks (with the same styles) in plain AutoCAD.
The data came from a SHP data connection.
I've try the "Save as AutoCAD drawing..." but they are all exploded.
Thank you
Simon, Montréal, Québec
8 REPLIES 8
Message 2 of 9
>>>..."Save as AutoCAD drawing..." but they are all exploded...<<<
That is what that command option is designed to do, dumb down your file aka explode everything, for general CAD use like in AutoCAD.
Looks like you are hoping to export features not found (or handled) in plain AutoCAD: may I ask why?
Message 3 of 9
In the wizard for export, you need to check first option to keep block into block.
In my french language it's "Modifiable"
If you check 2nd option as "visuel" all elements are exploded. This option can be considered as "Plot to DWG" to keep exact visual render.
Olivier
Olivier Eckmann
Message 4 of 9
Merci Olivier!  Ça fonctionne!
Pour une raison que j'ignore, le "wizard" ne s'ouvre pas si je passe par les ribbons (tel que montré ici).
En utilisant la commande MAPTOACAD, ça me donne accès au "wizard".
Encore un fois merci!
et vive la France!
Message 5 of 9
Hi @Simon_Thouin-Verdun , you can also ask your AutoCAD questions (all verticals) on our French AutoCAD forum: https://forums.autodesk.com/t5/autocad-tous-produits-francais/bd-p/127
Bonjour, vous pouvez également poser vos questions sur AutoCAD (toutes versions verticales comme Map) sur notre forum AutoCAD français : https://forums.autodesk.com/t5/autocad-tous-produits-francais/bd-p/127.
Patrick Emin animateur de la communauté francophone
Vous avez trouvé un message utile? Alors donnez un "J'aime" à ce message!
Votre question a eu une réponse satisfaisante? Voulez vous avoir l'amabilité de cliquer sur le bouton
 APPROUVER LA SOLUTION  en bas de la réponse qui apporte une solution?
Signez notre Livre d'Or
Message 6 of 9
Bonjour,
Personnellement, j'utilise très peu le ruban. Je fais toujours l'export depuis le volet des tâches à partir de l'icône carte.
Olivier
Moderator note: English version added:
Personally, I don't use the ribbon very much. I always export from the task pane using the map icon.
Olivier Eckmann
Message 7 of 9
Pointdump
in reply to: O_Eckmann
Hi Olivier,
I'm trying to follow along and learn something. Where is the "Wizard for Export"? How do you get to the Screen Shot shown in your Message #3?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 8 of 9
You can access the wizard by using the MAPTOACAD command.
Message 9 of 9
Simon,
Thank you. I learned something new. I just now tried this using Olivier's method and it works very well.
Dave
Dave Stoll
Las Vegas, Nevada
