I've created multiple thematic rules with each a different style and I was wondering if it's possible to export them as blocks (with the same styles) in plain AutoCAD.
The data came from a SHP data connection.
I've try the "Save as AutoCAD drawing..." but they are all exploded.
Thank you
Simon, Montréal, Québec
Solved by O_Eckmann. Go to Solution.
In the wizard for export, you need to check first option to keep block into block.
In my french language it's "Modifiable"
If you check 2nd option as "visuel" all elements are exploded. This option can be considered as "Plot to DWG" to keep exact visual render.
Olivier
Olivier Eckmann
Hi @Simon_Thouin-Verdun , you can also ask your AutoCAD questions (all verticals) on our French AutoCAD forum: https://forums.autodesk.com/t5/autocad-tous-produits-francais/bd-p/127
Bonjour, vous pouvez également poser vos questions sur AutoCAD (toutes versions verticales comme Map) sur notre forum AutoCAD français : https://forums.autodesk.com/t5/autocad-tous-produits-francais/bd-p/127.
Bonjour,
Personnellement, j'utilise très peu le ruban. Je fais toujours l'export depuis le volet des tâches à partir de l'icône carte.
Olivier
Moderator note: English version added:
Personally, I don't use the ribbon very much. I always export from the task pane using the map icon.
Olivier Eckmann
Hi Olivier,
I'm trying to follow along and learn something. Where is the "Wizard for Export"? How do you get to the Screen Shot shown in your Message #3?
Dave
Dave Stoll
Las Vegas, Nevada
Simon,
Thank you. I learned something new. I just now tried this using Olivier's method and it works very well.
Dave
Dave Stoll
Las Vegas, Nevada
